IPB
Здравствуйте, гость ( Вход | Регистрация )
Ответить в данную темуНачать новую тему
> Mercedes-Benz Specifications for Operating Fluids, Mercedes-Benz Спецификации на жидкости
playfox
сообщение 21.5.2009, 18:49
Сообщение #1
Пользователь
Из: Алма-Ата
Может кому-то пригодиться.
Спецификации
P.S. Если icon_bayan.gif , то сильно не пинайте.
Сообщение отредактировал playfox - 21.5.2009, 18:50
1998-2004 MB190E 2.3 5-mex 1993 (сбили)
май 2008 MB190E 2.5-16v 1990 automat
Перейти в начало страницы
+Цитировать сообщение
сообщение 21.5.2009, 19:03
Сообщение #2
Командир надувного танка
Администратор
Из: Минск
SHEET DESCRIPTION
000.0 Preface
022.0 Obligations Regarding Approval for Operating Fluids
023.0 Hazardous substances
110.1 General information on fuels
112.0 Fuel hazard classes
119.0 Additives and secondary additives for fuels
121.0 Gasoline engine fuels in the Federal Republic of Germany
121.1 Fuel qualities for MB cars, cross-country vehicles, vans and Unimogs fitted with gasoline engines
122.2 Minimum requirements for unleaded gasoline fuel
124.0 Antiknock rating of commercially-available gasoline fuel in Europe
124.1 Knock resistance of commercially-available gasoline fuel in Africa
124.2 Antiknock rating of commercially-available gasoline fuel in America
124.3 Antiknock rating of commercially-available gasoline fuel in Asia
124.4 Antiknock rating of commercially-available gasoline fuel in Australia
125.0 Fuels for gasoline engines
126.0 Sulfur in gasoline
127.0 Fuels for natural gas gasoline engines
131.0 Fuels for diesel engines
132.1 Minimum requirements for fuels for diesel engines (DIN EN 590)
132.3 Minimum requirements for fuels for diesel engines (ASTM)
133.0 Calibration fluid for diesel injection equipment
134.0 Aviation turbine fuel as diesel fuel
135.0 Fatty acid methyl ester (FAME) as diesel fuel
136.0 Sulfur in diesel fuel
136.1 Worldwide sulfur content of commercially available diesel fuels
137.0 Winter operation with diesel fuels
137.1 Flow improvers for diesel fuels
138.0 Microorganisms in diesel fuel
138.1 Microbiocides for these fuels
141.0 Diesel fuel for industrial engines
210.0 General information on lubricants
211.0 SAE viscosity grades of engine/gear oils
215.0 Use of lubricating oils
219.0 Special additives for lubricants (vehicles and engines)
221.0 Requirements in respect of engine oils
222.0 Use of single-grade / multigrade engine oils and high-lubricity oils
223.1 Specified break-in engine oils - overview
223.2 Specified engine oils (service) - overview
224.1 Viscosity classes of engine oils (car engines)
224.2 Viscosity classes of engine oils (CV engines)
225.0 Approved initial operation engine oils
225.10 Multigrade break-in engine oils (Specification 225.10)
225.11 Low SPAsh multigrade break-in engine oils (Specification 225.11)
225.12 Low SPAsh multigrade break-in engine oils (Specification 225.12)
225.14 Low SPAsh multigrade break-in engine oils (Specification 225.14)
225.5 Multigrade break-in engine oils (Specification 225.5)
225.6 Multigrade break-in engine oils (Specification 225.6)
226.9 Multigrade engine oils (Specification 226.9)
228.0 Single-grade engine oils (Specification 228.0)
228.1 Multigrade engine oils (Specification 228.1)
228.2 Single-grade engine oils (Specification 228.2)
228.3 Multigrade engine oils (Specification 228.3)
228.31 Multigrade engine oils (Specification 228.31)
228.5 Multigrade engine oils (Specification 228.5)
228.51 Low SPAsh multigrade service engine oils (Specification 228.51)
229.1 Multigrade engine oils (Specification 229.1)
229.3 Multigrade engine oils (Specification 229.3)
229.31 Multigrade service engine oil Low SPAsh (Specification 229.31)
229.5 Multigrade engine oils (Specification 229.5)
229.51 Low SPAsh multigrade service engine oils (Specification 229.51)
231.0 General gear oils
231.1 Specified gear oils (cars, cross-country vehicles) - survey
231.2 Specified gear oils (commercial vehicles) - overview
231.3 Prescribed gear oils (UNIMOG, MB-tractors) - overview
235.0 Hypoid gear oils (SAE 90, 85 W-90)
235.1 Gear oils (Specification 235.1)
235.10 Gear oils (Specification 235.10)
235.11 Gear oils (Specification 235.11)
235.12 Gear oils (Specification 235.12)
235.13 Fully synthetic commercial vehicle transmission oil (for manual transmission)
235.15 Hypoid gear oils (SAE 75 W-85, Specification 235.15)
235.20 Commercial vehicle hypoid gear oil mineral oil (Specification 235.20)
235.27 Commercial vehicle retarderoils, categorie Voith A
235.28 Commercial vehicle retarderoils, categorie Voith B
235.29 Commercial vehicle retarderoils, categorie Voith C
235.4 Synthetic gear oils (SAE 75W-85W)
235.5 Gear oils (SAE 80, 80W-85W)
235.6 Hypoid gear oils (SAE 90, 85W-90, Specification 235.6)
235.61 Hypoid gear oils (Specification 235.61)
235.7 Universal hypoid gear oils
235.71 Gear oils, smart (Specification 235.71)
235.72 Automatic shift gear oil typ 451 and 454
235.8 Hypoid gear oils (SAE 75W-90)
235.9 Differential oils (Specification 235.9)
236.1 Automatic transmission fluids (ATF, Specification 236.1)
236.10 Automatic transmission fluids (ATF, Specification 236.10)
236.11 Automatic transmission fluids (ATF, Specification 236.11)
236.12 Automatic transmission fluids (ATF, Specification 236.12)
236.13 ATF (Specification 236.13)
236.14 Automatic transmission fluids (ATF, Specification 236.14)
236.2 Automatic transmission fluids (ATF, type A, suffix A)
236.20 CVT transmission oil (ATF, Specification 236.20)
236.3 Steering gear oils (ATF)
236.6 Automatic transmission fluids (ATF, Specification 236.6)
236.7 Automatic transmission fluids (ATF, Specification 236.7)
236.81 Automatic transmission fluids (ATF, Specification 236.81)
236.9 Automatic transmission fluids (ATF, Specification 236.9)
236.91 Automatic transmission fluids, Allison transmission (ATF, Specification 236.91)
261.0 General lubricating grease
264.0 Liquid grease (NLGI grades 00/000)
265.1 High temperature antifriction bearing grease (NLGI grade 2)
266.0 Grease (NLGI grade 1)
266.2 Long-life grease (NLGI grade 2)
267.0 Multipurpose grease (NLGI Class 2)
267.1 Wheel bearing grease (NLGI grade 2)
268.0 Leaf spring grease
269.2 Complex grease (NLGI grade 2)
310.1 Coolant Specifications
311.0 Coolant refining agents
312.0 Coolant additives (water-soluble) without antifreeze protection requirement
325.0 Anticorrosion/antifreeze agents (Specification 325.0)
325.2 Anticorrosion/antifreeze agents (Specification 325.2)
325.3 Anticorrosion/antifreeze agents (Specification 325.3)
326.0 Premixed coolant (Specification 326.0)
326.3 Premixed coolant (Specification 326.3)
330.1 General brake fluid
331.0 Brake fluids (DOT 4 plus)
331.1 Brake fluids (DOT 4 type 200)
332.0 Brake pad paste
341.0 Tipper and hydraulic fluids
342.0 Hydraulic fluids (Specification 342.0)
343.0 Hydraulic fluids (Specification 343.0)
344.0 Central hydraulic fluids
345.0 Hydraulic fluids (Specification 345.0)
350.0 Lubricants for electrical equipment
352.0 NOx reducing agent AUS 32 ("ADBlue") for SCR systems
361.0 Refrigerants
362.0 Compressor oils
363.0 Compressor oils
371.0 Windshield washer fluid concentrate
380 Preservation of vehicles/engines
381.0 Preservation instructions
385.1 Wax preservation agents for underbody
385.2 Wax preservation agents for cavities
385.3 Wax preservation agents cavities (bus)
385.4 Wax preservation agents for engine compartment
Быстрый ответОтветить в данную темуНачать новую тему
1 чел. читают эту тему (гостей: 1, скрытых пользователей: 0)
Пользователей: 0
Текстовая версия Сейчас: 18.12.2017, 15:24
